Max Srating Capacity in 2002 Tige 2300V
    Where is the metal plaque attached on a 2002 Tige 2300V? I was checked by the water patrol this weekend. We had 11 people in the boat and he thought that was too many for the boat. We all had life jackets so he just checked registration and moved on. Is it possible to get a new max capacity plaque for my boat? If so, who do I need to contact?
    Depending on where you live it is not necessary to have a capacity plate. A lot of states only require capacity plates on boats shorter than 20 ft so this would not apply to your boat.
    The police guy was trying to hassle you.
      Mine is under the motor hatch. 21V is rated for 12.
        12 people on a 21 ft? I bet that gets a little crowded!
          Tige Specs
          http://www.tigeowners.com/model_specs.php
            My Z1 is 10, the R20 is 12, I bet that is a bit crowded
            Your boat is rated at 12
              Had 12 on yesterday. Not too bad if everyone leaves bags and such on the dock. All but 3 (adult sponsors) were 10th graders.
                I have the same boat. It is rated for 12 or 13, I can't remember as it is at storage currently. I keep the same rated amount of preservers on the boat.
                I would just call the factory and order a new plate.
                Boating Lake Mead since 2000
                  If someone can take a high resolution picture of their decal, I'm sure I can make one. Would have to be a clean straight shot with no flash obviously.
                    My 2001 2300V Limited has the yellow/silver USCG plaque mounted to the underside of the engine hatch.
                    The people capacity is 14 on that plaque, and I don't recall the weight. I will try to get a picture of it posted.
                    I have had 14 people on the boat before, but 8 of them were under age 10, which is the only (moderately) comfortable way to fit that many bodies on board!
                      I just asked the same thing and USCG only requires plate on boats shorter than 20ft. After that it was up to the MFG if they put a plate on them or not.
