What is the model number for the Acme 15" 5-blade? Will be measuring clearance this weekend for sure!
Cat out of the bag prop!
Originally posted by Wickedcummins View PostProp shop says 1/2 inch acme says 5/8 clearance I have 3/4 of a inch clearance!
No worries Im not stopping here two more props showing up tomorrow for some testing as well! I fill in with a final prop pick!Last edited by Wickedcummins; 05-21-2012, 04:52 PM.www.1320diesel.com Home of the Fastest Diesels!
Originally posted by Duncan View PostA 15" prop will not fit our 2009 RZ2. Prop guard clearance is not problem (1.5" with current 14.5" diam 1235). But hull clearance is 13/16" with the current 14.5" diam 1235 prop. A 15" diam prop would leave 5/16".
Originally posted by Timmy! View PostAlso, I'm wondering why a 2009 RZ2 would have different clearance than a 2011 RZ2 when they have the same running gear.www.1320diesel.com Home of the Fastest Diesels!
Originally posted by Timmy! View PostI think you are measuring wrong. If you have a 14.5" prop now and have 13/16" clearance and went to a 15" prop, that would be a .25" difference on the clearance (it's a circle). 13/16" - 4/16" = 9/16" clearance with the new prop.
So, I installed the 5 blade 2131 first on Saturday morning but the clearance to the hull was only about 3/8". I pulled it and installed the 1235 and had right at 5/8" so I ran with that for the day. They are both 14.5", why would the 2131 sit closer to the boat? Maybe the pitch of the prop?
Could I have tightened the nut too much? It said you only have to tighten it to 35lbs but I was using a wrench since I didn't have a deep enough socket for a torque wrench. I couldn't see the difference of a half turn or even a whole turn putting the prop a 1/4" closer to the hull but I could be wrong.
Given houstonshark's experience with actual clearance diameter on so-called 14.5" props, I wonder what the true clearance diameter of those 15" props are?
