2010 RZ2 vs 2011 RZ2
    Any difference between the 2010 RZ2 and the 2011 RZ2?
    Thanks!
    They only thing that I can recall would be the options that were added with each one.
      I think the vinyl might be slightly different. Was 2011 the year they added Surf Ballast as an option too?
        The 2011 also had the tower camera as a option.Different Vinyl pattern and a update to the Tige Touch system and i think it was the first year of the Vector Graphics.Carlotta steering wheel was new too and cupholders on the transom.I think the make up mirror under the observers seat was new too.
          You can update the taps with a firmware update, I would just be checking on the ballast option. You def want the pro ballast option if you can. The 2011 interior was a bit nicer, but the 2010 was still top notch.
          http://wake9.com/
            Thanks everybody. Appreciate the feedback!
              Yep Ragboy and Robert had it right on the nose with the upgrades! both boats were top notch!
                They are pretty much the same in my opinion.
                in 2011 they went with polished chrome Tige touch and replaced the round handrails around the boat with the square type.
                Also you could get the tower now painted to match your hull color. 2011 Tige touch software update as well.
                Other than that I don't think the really big differences came around till the 2012 with the tower cam, front cooler, two piece snap in carpet, etc..
                If your deciding between the two year groups to buy, I'd save the extra $$ and buy the 2010, practically the same boat.
                My 2010 has cupholders on the transom, no makeup mirror, and surf system...
                2010 Tige RZ2 "Fully Loaded" 650hrs
                Surf Ballast & Enzo Bag - 1235 prop
                  My 2011 has a tower camera,two piece snap in carpet and the carlotta steering wheel is sweet.
                    anyone know if there is a 2012 update ?
                      Not that I have found between my 2011 and the 12'
