I just got an 05 22V and the fuel gauge sits on full the entire time Im on the lake. Dealer said it might be a ground problem. Has anybody else had this problem.
Fuel Gauge
Does anybody know which flow meter is the best and where to get it. Is there a gauge small enough to fit in a pod the same size as a taps gauge.Everything happens for a reason
Here the link to another thread where I posted pictures of my fuel flow meter after I installed it.
http://www.tigeowners.com/forum/show...r&pagenumber=3-Tip
So has Tige fixed the issue???
After reading this thread and the others that were referenced, I am curious if Tige has made a change in the 06 models...let's see, how about the 24Ve as an example...to minimize or eliminate the issues with the fuel gauge. The fuel gauge in my former deck boat never worked right and it was always a source of curiosity, wonderment and frustration. If it is still an issue, perhaps I should go ahead and get the fuel flow meter installed before we get our boat...It hasn't arrived in So Cal from Texas yet...so time is on my side...
Nick or somebody from Tige, do you have any insight on the fuel gauge issue for the 06s... Thanks...
Wake Havasu
Originally posted by CP3
does anybody know if there is a navman website for a the flowmeter.
http://www.navman.com/marine/products/fuel/index.html
It says on the site that the 2100 is suitable for engines up to 300 hp but mine is 340 hp. Does it really matter or do I need to get the 3100.Everything happens for a reason
It states on there site that it is good for up to 300hp, but it also states that it is designed for flue flow rates of 1.4 to 35 gallons per hour.
I have a 350(5.7) at its hp is rated at 340, I run around 5 gallons an hour.
I installed this in my boat last winter, and love it.
If it tells me that I have used 25 gallons of gas, then when I fill it I will be some where around 24 to 24.5 at the pump.
I could calibrate it to make it more accurate. But I have not bother to do so yet.
If you install one, just make sure of two things.
1) You install a flue filter before the transducer.
2) You need to install the transducer before the flue pump (Marine power engines)
Also I do know that this will not work on PCM engines (as they have a return to the fuel tank)
http://www.navman.com/marine/product...100/index.htmlAttached FilesTige, it's a way of life!
If you install an additional fuel filter be careful, my Mercrusier manual (350 MPI) says adding an inline filter (in addition to the factory filter) can cause the engine to run lean. Running lean would help your fuel economy but could cause long term damage to the engine. I'm not sure if the same would apply to the Marine Power engine.
I chose to not install the additional filter. My 22v with the Merc 350 MPI has never operated less than 7 gal per hour (even with no ballast) at wake board speeds.
Was your boat only using 5 gal per hour before you put in the filter?-Tip
