I have a 2001 21v with the 350mpi. I was wondering how much oil I have to add when changing the oil and filter? Same thing with the transmission And how do I drain the transmission? Thank you.
winterizing
I usually use about 4.5 quarts when changing the oil and filter. I think the capacity is 5.
I'm not sure about how to drain the transmission. I use a big syringe with a little rubber hose to extract the transmission fluid. I then replace the exact amount I extracted and check the level from there.
TipLast edited by Tip; 11-19-2005, 04:10 AM.-Tip
