'06 20V Steering Cable Size?
    Looking all over the internet for the cable size and cant find it. Have to change it in a few weeks and hoping somone knows the size.
    Thanks!
    Have you checked to see if you can see the markings on the existing cable?
      Have not checked that yet. Guess I might have to pull it out first.
        It's a 18' cable. I just did mine. If you route it behind the port battery storage right behind the drivers seat, I would order a 17'. It much easier to do it this way rather then go down through the floor and over the front of the tank. You have to pull the tank if you do. Even with drilling two holes through the rear storage and into the engine compartment, it's an hour job you can do by yourself. It took me longer to figure out that I wasn't t going to route it over the tank than it did to just route it the easy way.
