When to have a prop repaired
    Looking for some practical wisdom regarding the 4-blade prop on my RZ2. Two years ago it touched a rock while beaching, and one blade has a very slight deviation on the outer edge. I massaged it back with a cardboard-lined crescent wrench, so it is fairly close but still not correct. I ran it all last year with no apparent vibration or loss of power or cavitation, but I'm sure it is not at 100%. How do you decide when to have a prop tuned/repaired?
    Sooner is always better. The fact you made it better is good on you. If you can't tell its bent, you're probably alright. I guess its up to you how much piece of mind is worth.
      the next day, once you change it with you spare prop
      Tige, it's a way of life!
        x2. That is the best suggestion. I bent mine three times. Fixed it like you did twice. The last time was bad. Sent it in over this winter and it is back on the boat now. I need a spare.
        Wake Up or Stay On Shore!
          Finally took my prop to Hill Marine in Tustin CA, and I showed him the minimal ripple on one blade. He promptly looked at it and showed me how all four blades were deflected back almost 1/4" out of shape! There is no damage to the prop, and I don't remember ever running it in sand or the like. Maybe the thrust of wakeboard/skiing starts causes the blades to flex back over time? Anyway, now it looks great and I can't wait to try it out this summer.
