I have a 2004 22V. While under somewhat of a load, such a pulling a wakeboarder, I cannot turn to the right with a normal turning radius (the radius is about double that of turning to the left). When I pull back on the throttle almost fully, even though the wheel is already turned fully to the right, I can feel the rudder "break loose" and then the boat turns in its normal radius.
Has anyone else experienced this? The dealer tells me it is normal and is caused by the prop turning to the right but it does not seem correct.
Thanks in advance for any help.
