I have a 2100V and i am having a very tricky time getting the wake to smooth out. Does anyone have any suggestion or I'm i better off just learning how to wake board better? Thanks for any help.
If you have a taps plate play around with the setting between 0 and 2. If you have any ballast you might want to try using some bow ballast, obviously no ballast in the back, try to keep it as light as possible, with just a little ballast to keep the bow down. Speeding up will knockdown the height of the wake as well.
