throttle/ transmission cable
    What is the part number for the tele flex control cables for throttle and forward/ reverse. It is a 2001 21v. I know they should be the same for all the 21 ft boats.
    The teleflex/morse cable has a part number stamped into it close to either end, use that number.
      Did anyone find the teleflex number for the cable. My cable says cc663316 and I can't find a throttle cable with that number.
        That's a standard 33c cable that is 16' long (last two numbers indicate length). Throttle cable should be close to the same if not the same.
          Thanks I order the cc633 cable that is 16 feet
