First things first... here are a few pics of a new to me, 2000 2300V we purchased out of Portland, OR this year. 227 hours on the 5.7 Black Scorpion. I have since installed perfect pass and purchased 4 manual ballast bags (1800#) for surfing. Zero issues bringing the boat back to Canada. This summer we managed 50+ hours - not bad for a 3 month season. No regrets about the purchase. It has been a fantastic boat.
The winters here in Alberta can last from October to April so I wanted to protect the engine and cooling system. I winterized last weekend using the following process and would appreciate any feedback.
I added fuel stabilizer to the gas tank and with the boat in the water (still on the trailer) I attached a remote fuel hose at the water separating filter and to a jerry can containing a mixture of 2 gallons of fuel, 2 stroke oil, stabilizer and mercury fuel treatment. I ran the engine at 1500 rpm for 10 minutes - it only used 2 quarts of the mixture. ( I thought it would use more of the mixture, next year I will use less).
As for the antifreeze, I removed the 6 freeze plugs to drain the block and hoses. I was prepared to remove the thermostat assembly and thermostat to pour in the antifreeze when I noticed (what appeared to be) 2 fill plugs on either side of the thermosat. So I removed these plugs (approx 1") and poured in the antifreeze until full (approx 14L). I then loosened each freeze plug to ensure the antifreeze reached all areas (and it did).
For good measure I removed the cooling hoses from the transmission / sea water pump and drained the small amount of remaining water into the bilge, which drained through the hull plug.
Afterwards I changed the oil, filter, lubricated all cables, cleaned the flame arrestor, greased the rudder box, checked the v drive and tranny fluids, checked the prop nut and removed the batteries. I also removed the sunpads to allow air flow while covered for the next 9 months. Then I finished with a good cleaning inside and out
My main questions:
1. Was 2 quarts enough winterizing brew to run through the engine?
2. Was I OK to pour antifreeze into the 2 fill plugs rather than remove the thermostat?
Thanks for your advice.
Scott
My main questions:
Scott
