Looking for a little help on this guys.
I recently picked up this 2000 21v w/Merc.350 Mag. which ran fine when I test drove it. Now I am having fuel supply issues to the engine...Like none, nada, non-existent.This all started after I did a bilge and engine bay clean out after I brought it home from where I bought it.I hosed out all the pet hair, leaves, slime, and bilge spooge and sucked out the residual debris with a shop vac.(some people have no respect for their investment)...but the hosing out shouldn't have caused the fuel pump to malfunction should it? Getting things wet on an engine should be a pretty common occurrence on this boat...right?
Has anyone ever had to replace a fuel pump on the Mercrusier 350 Mag in a Tige V-drive?
It is tucked down on the back side of the engine with a protective plastic cover over it. It seems virtually impossible to remove the plastic cover alone without breaking it let alone the fuel pump.I am in the process of testing the pump before I decide to replace it. Any type of advice would be appreciated.
Thanks
Thanks
