In my area this is the 1st year ethonal gas is now being sold year round instead of just winter time. Last years tank of gas ran great even with a small fill up but then after the next 20 gallon fill up felt a sluggish and now the hole shot sucks. Feels like a 100 hp or more is now lost and takes off like a I/O. My boat is a 09 tige 22ve v-drive 340 horse PCM. Need addatives? Other Problem?
S.O.S on ethonal gas.
Originally posted by robert theisen View PostMay be the fuel filter.HOW many hours?How old is the gas in it?Does it misfire?
Doesnt sound like an ethanol problem. Its not like a poison that's lethal after one dose. Its been run in hi-way vehicles for years with no ill performance effects.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by duckboat View PostGas is premium for every fill up.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostStop using premium and use 87 oct if you can.
Originally posted by duckboat View PostOk good thats what someone at a boat shop told me today when I was asking about addatives. Don't use the good gas because it doesn't alarm the knock sensor I was told causing the computer to think it is broken. He explained limp mode to get home but I think it has too much power for that. Addatives have mixed results and the guy told me he was not a believer in them but has a friend that runs another shop who is!?
Additives are great as a preventative, but do not usually cure ailments.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Found a station in my area that sells non-ethanol gas. Going to drain some gas out of the boat and into the car then fill the boat. Hope this works and gets rid of that 1972 bayliner preformance as my friends told me how it was running the other day since the e10 is becomeing the norm around here. In away I hope it might be another little problem because if it's the ethonal my boating days are over since it sounds like all gas will have ethonal in the near future.
I'm with CHP on this one, probably not a problem with ethanol in the gas but in the fuel filter. I know when ethanol first came out, it disolved and broke up some of the varnish on the bottom of tanks without ethanol. When people started putting E10 gas in their boats it would dislodge sediment and gunk from the bottom of tanks and clog the fuel delivery system. If I were you I would replace the fuel filter and keep putting E10 gas in it since its slowly taking over everywhere and maybe run a tank or two of gas treated with SeaFoam to help clean up the fuel system.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Originally posted by ktm450exc View PostI have the fuel injected Black Scorpion motor in my boat. Are you saying I should NOT use 92 or higher octance? I have been running 92 with 10% ethanol in my boat for years and I have yet to have a problem.
2nd) im saying its a waste of money to use the more expensive fuel just because the commercial says its better.
3rd) there's no correlation between the octane level and ethanol %. If ethanol is mandated in your area, you will find it in all the grades. There is no advantage to running the 92 w/ethanol over the 87 w/ethanol.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Marine Sta-bil every tank full......no problems!
http://www.goldeagle.com/brands/stabil/default.aspxAttached Files
