Hey guys, I was on the way back in the other day after cruising around 3400 RPM for about 15 minutes. Everything was fine, and I started backing down getting close to the dock and at about 3000 RPM I felt a sudden slight loss in power and the boat picked up a vibration. I can still pull through the RPM range pretty strong, but around 2500-3000 RPM it shakes bad. I ran it in my driveway yesterday trying to troubleshoot, and although it's not nearly as noticeable with no load on it, I can still barely feel the vibration and hear what almost sounds like a slight miss in the engine in that same RPM range. It's not intermittent or random, it's a very steady "not right" kind of sound. above 3000 it seems to smooth out, but that may just be b/c everything is spinning fast enough not to hear it.
My troubleshooting so far: at idle, pulled one plug wire at a time and could definitely hear a difference. checked all the wires at the cap and the plugs. checked the oil for water, checked the tranny oil, and the v-drive oil. everything seems fine. engine temperature is normal. no smoke or weird smells out the exhaust. checked the prop and shaft, and both look completely fine.
Thoughts? Thanks guys.
