i've ridden in 2 2003 22v's.....from my experience the best setups are a combination of lead and sacs.
600# sac on each side of the motor, and another 600# in the bow/walkway.
add about 3 or 4 100# lead bars and you are good to go! The lead lets you fine tune the wake if the boat weight is un-even. For instance, when there are jsut two of you, you can put a few lead bars on the port side to counter balance the weight of the driver.
top it off with about 5 or 6 friends, and you'll have a super sweet wake.
