I have a 2001 2100V Limited and while idleing I can hear an intermitent whir or buzz coming from underneath the floor right where the fuel tank sits. It is very quiet and the boat seems to be getting plenty of fuel.. but the noise just scares me..should I be concerned about the fuel pump because that is the only thing that sits right there.. are there any sort of tests I can do to make sure the one I have is operating properly.. Also.. sometimes when I am running the boat with out the prop engaged.. and rev up a little.. if I cut it back directly to neutral the engine will stall.. It will start right back up but I just thought I would add this in there in case it was related.
Thanks
Mike
Thanks
Mike
