I have an 08 22VE with the stock bimini from Sunbrella. It zipps to the to back top part of the tower & the lower front part of the tower is below the bimini & exposed. The bimini has 2 cut outs which I am guessing are for the tower speakers. The problem is the light bar can fit inbetween but the bimini will not fully zip now. should I use the front lower part of the tower instead?
Tower speakers & light bar on 08 22VE
For the factory install, Tige mounted the speakers on the forward hoop. personally, If i was adding speakers, I would have a canvas shop modify the bimini so it worked around the speakers mounted on the rear hoop.Is the light bar factory? Pics might help.
