My impeller went out and I need to know what type I should buy and how is the easiest way to change it? Any threads or pics. Thanks.
What type of impeller for 22ve 2006?
my impeller was fine... so I need to figure out what might be causing a clog in the lines...because the boat is overheating after about 5 minutes of running it at 10 mph... does anyone have any pictures of exactly what hoses to put a hose to and backflow water to make sure its clear?
thanks...Work Hard, Play Harder!!!
No pics, sorry.
1st,locate the trans cooler. There is a marine power winterizing thread somewhere that has a pic of the trans cooler. Once located, pull the inlet hose off. Thats the hose running between the trans cooler and the V-drive asm.
2nd, pull the inlet hose off the bottom of the impeller housing. Shove the garden hose in this hose and tune the water on and see what comes out of the inlet side of the trans cooler.
If nothing comes out, then move the garden hose to the hose you pulled off the trans cooler and back-flush the v-drive and scoop. Place a bucket under the scoop to see what comes out.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
