Help! I guess in my old age I am having a tough time making decisions?!@#?^??
Well too cold to work on stereo so I might as well install my board racks. However I need some advise. Seems I have 2 choices, to mount the racks #1 on the pipe, or #2 on the uprights.
1.
1st possible position. If I mount them on the pipes I feel that they would be to far to reach up and not very easy to grab the boards. I think the racks would have to be mounted on the pipe just alittle bit forward of the top bolt of the upright. Commments or ideas on this position?
2nd possible position. If I where to mount them on the uprights, it will require quite a bit of detailed work to make them fit right. As you can see once I take off 1/2 of the pipe clamp there are a number of nibs. I would have to drill holes into the upright to make it fit. Maybe I should grind down a couple on just have 4 nibs or even 2?? I do need some nibs to prevent the rack from twisting down. Has anyone installed these racks on the uprights?Also if I went this route do you think I should drill sraight through the upright or only half way and grind down the nibs?
Also do you think the uprights are strong enough so once the boards on on them they won't shake alot?
2.
And the most important question and I hope someone will chime in to help. DO you think I should use the "Tige" upright or the plain "curved" ones.
Also I was thinking of getting these powder coated silver or even chromed. What do you guys think?
I would appreciate all the ideas I can get!! Thanks
3.
4.
3.
1.
2.
3.
4.
3.
