I was only able to use my boat about 5 times after I bought it last fall. I do not think that the bilge pump is working. Is there an easy way to check it? I could not hear anything and I tried to put my hand on it but did not feel anything. At the inspection stations before I could launch it i was asked to turn it on and I flipped the switch and was told I was good. One person even put their hand over the outlet when they asked me to turn it on. I tried it and did not feel anything.
I believe that it is a Rule Mate 500 GPH. If I get a new one should be able to use the same base and just switch the two units? Is there any value in replacing it with the 750 GPH or 1100 GPH? With the few times that I had it out I never saw any water in the back by the pump. All the water accumulates in front of the engine and only drains when I am on a steep hill. I still have wondered where the water even comes from?
One thing that might be of consideration is that got a custom surf sac, thanks Chp, would either the weight being in the back causing the water from the center to flow toward the back or the possibility of the bag breaking be a reason to go bigger?
Thanks for any input.
