I recently bought a 2ooo 21V Riders addition, I knew that taps was not working when I purchased the Boat. The shop was able to get it working by topping off the fluid. It worked for one outing but had a bad connection and lost fluid. I had the shop replace some connections and install new lines. It worked about 10- 12 hrs on the water. Huge improvement but once again having problems. anyone have similar problems? Recomendations?
Taps
This is a pretty common problem it seems and there is a lot of info on this site about repairs, search TAPS.
I'd recheck the electrical connections near the pump. I was advised that the pump would still run even if the fluid was low, though I topped it off also.
Basically, I cut the wires then stripped them and reconnected, not a problem since
