Before replacing the regulator (I doubt that's the cause of the high fuel pressure) I would look for a kinked or collapsed fuel return line.
A closed or seated regulator, such as when the engine is off with key on and fuel pump is running, or when there is no vacuum to the regulator, puts the pump at max PSI. This max PSI is only about 12-15 PSI above the normal operating PSI. 100 PSI sounds like a "dead-head" reading that one would get if you were to pinch off the return line. So, in theory, a stuck regulator would give you the closed or seated PSI reading. Do you have a car that you could test the fuel pressure gauge on? A bad gauge could also be at fault here and since you just bought it........
