2004 24V with the Marine power 5.7L
Dealer put in a new distributor and changed all fluids/filters. I put in a new battery, new alternator (dealer said it was shot) and changed the plugs.
It would fire up before the work was done but would only run in limp mode, but now after all that it'll fire up and run (rough) for about 30 seconds then just turn itself off and then not start again (still cranks...just won't start). Tried again the next day...ran for a few seconds and then turned itself off again and wouldn't start again.
Ideas? Seems like it's potentially starved for fuel? What's an easy way to check that?
I didn't gap the plugs when I threw them in...so not sure if that could be causing this. Lost my gapper.. but I'm going to go grab another today and pull them and check the gaps.
... anyhow the gauge pegged at 100 psi for the entire time it was running. Regulator?
