Hello there,
I just bought an 01 21V and the throttle was replaced with one that does not control the TAPS plate. I purchased an (on)-off-(on) toggle to go on the dash and replace one of the ACC switches.
I found a white sheathed wire that is cut and appears it was ran to the throttle area. It has three small wires inside it; red, white and black. Does anyone think this it the wire that I should hook to the new switch? Also, I suppose the red one is the power and should be attached to the middle post and the other two should be attached to the two outside posts on the switch??
Any comments or suggestions? I am not above just hooking stuff up and seeing what happens either.
Thanks!
Thanks!
