Finally getting around to fitting my Heatercraft 3 vent heater, and including it in my closed water system.
(I live in the UK and run in the sea - saltwater).
If you think its cold there, should try the water temp/ weather here most of the season!!!
Think this will get a fair bit of use when installed.
Will be fitting the matrix in the drivers cubby and 1 euro vent directly under the dash/ kick plate.
Looking at other threads I see the most common locations for the Hot-tubes are in the walkway and in the base behind the drivers seat.
Anyone got any pics of these fitted?
Would like to fit them similar to the factory installed / best location, and you only get one go at this.
Fancy also getting a walk-through screen and not sure if the vent will fit infront of the door on a 20V along with the slider for the screen, anyone tried this?
