engine hatch/rear storage gas shocks
    hi all
    my tige doesnt have the gas shocks that support the rear engine lid and storage hatches on the rear, where would i be able to get these as i dont want the hinges to snap off
    kind regards jacob
    I just got some from a dealer. You better get your check book out because their not cheap!
      I have some coming from Tige on Warranty, They are backordered
        just search gas springs on the internet. SPD is where I got mine. If you don't have a set to get the number off of your going to probably need to contact the dealer to get the proper length and pressure? Maybe the people at the spring place would be able to get what you need? I ordered some that were too stiff, having to change them. There like $15 each.
          you will need to know length when extended and length when compressed as well as the pounds of lift. you can find the black ones cheap but if you want the stainless ones its going to cost ya. I just replaced all of my black ones with the SS ones along with the brackets and it was pricey.It looks good though . Mine were very rusty and I had it all apart redoing the interior so I could not see putting those rusty crapy ones back on.
            What boat do you have?
            Our 2000 21V came with the following gas springs with end style EF-PS30B1:
            engine cover - SPD-GS-6984 (SPD-GSNI-5150-60), 15” x 9” x 6”, 6mm x 15mm
            storage lockers - SPD-GSNI-5250-60, 18.5" x 11" x 7.5”, 6mm x 15mm
            dash compartment - SPD-GSNI-5200-40, 17” x 10” x 7”, 6mm x 15mm
            The original no.s from the springs are GS and are now GSNI for the new black nitride shaft series.
            Here's a table of what SPD carries: http://www.spdhardware.com/catalog/l...52741324413%7D
            The engine cover gas spring was a Tige custom ordered version, but the 5150-60 is close.
            The mounting brackets are extra.
              how much are they usally from dealer?
                I have a set for sale brand new, only used for a couple weeks till I determined they are too stiff.
                Model GSNI525060 from spdhardware.com I will sell them too you for $20 plus shipping.
                  1998 Tige gas springs
                  Does anyone know the part number for the gas shock supports that hold the rear sundeck on a 1998 Pre2050? I just bought the boat and the shocks are missing. Thanks
