Put my 2005 22v in last weekeend and taps didnt operate, temp gauge pegged 250, loud beeping,light flashing son of gun.
Was this like all at once? Sounds like a loose ground for the helm
On my '01 21v my switch was shorting out at the handle and the taps would not move but the gauge wouldshow that it was getting power but wouldnt move. I relocated the switch to the switch panel.
2001 Tige 21V Fresh Air Exhaust, ballast, loud stereo, blue v drive, ACME 1235 prop Kneeboarding, Surfing, and having fun!
I did have the taps plate not move after I moved the switch, I ended up tapping on the hydraulic pump with the but of a screw driver, and it worked after that.
