Tige 2300 Limited
    Tige 2300 Limited
    I need some help. I just purchased a 2001 Tige 2300 Limited. Engine runs great but I need to replace a lot of the electronics. My gauges don't work besides the Perfect Pass. My fuel/engine temp/oil pressure guage stays at the same mark no matter what. The old Faria guage that, at one time showed the depth and several other things looks like it's melted. RPM guage is good I assume but not completely sure it's accurate. The taps system is broke. It need a new throttle switch and relays etc. the hydronic motor works though. I know its an older boat but any help would be greatly appreciated. Thanks
    I found the Faria gages on this sight. You can check out the company websight and match them up. I think I also found model numbers for some of them on this sight. You’ll have to use the search feature to locate them quickly. I was having trouble with my temp gage. Ended up unplugging the wires on the back and plugged them back in and everything started working as normal again.
