Throttle tight
    Throttle tight
    2012 RZR 343 pcm throttle is very stiff in forward gear. Can shift and drive but very stiff. Used to be smooth and buttery. Wondering what to look for and how to fix.
    Any tips help
    There is a push pull cable to operate the shifting. Check to see if it's binding anywhere, a little grease on it can also help,
      Believe throttle is by wire but shifting gear is cable to transmission. Check metal sleeve around cable just where it connects to trans. If it is bent just a little it will make shifting harder. It easily gets bent if you have any service done, because it’s in the perfect spot to support yourself while doing maintenance.
