2019 RZX prop for high elevation
    Hello all,
    I have a 2016 RZX that I just had a 2:1 transmission installed in. I surf at Lake Tahoe, 6,200 ft. Shop is asking what prop I'd like. Either 17X14 or 17.25X13. With the 1.5:1 transmission I had to run such an aggressive prop I lost the ability to cruise much above 25mph. I put 2019 RZX in title because that is basically what this is now drive train wise. Any one own an RZX with the 440 and surf at high elevation?
    The Tige offered high altitude prop is the Acme 2755 which is 17x14.
      Thank you Lee. Your input as a Tige' guru is always appreciated
        I’d also recommend the 17x14. Never ran out of power with that prop.
