So I had an unfortunate occurrence which a hydrophase ridesteady issue and I burned up a transmission towards the end of last season… I took my time getting it apart, rebuilt, and reinstalled up until this point… Im questioning myself here… I cannot confirm or deny how long the prop shaft seal has been there or really how much if any play there is or should be in it… it didn’t leak before… I have seen or heard before about adjusting all 4 points of the engine/tranny mounts and using feeler gauges to plumb up the Vdrive and prop shaft… I didn’t move any adjustment/ when I took everything out… when I put it back in, this is where I’m at… anyone else done this? Considerations? Techniques? I’m all ears… thanks in advance friends!
PS ignore the antifreeze as I was winterizing and dropped some into the bilge…
