Took the boat out with a potential buyer hit a wave hard and the boat alarm started going off. Had to put into nuetral and re-start ran fine in smooth water….any ideas where to find the issue. I replaced the ECOS at the beginning of the year and the connections seem fine…beyond that I’m not sure where to begin…I appreciate any assistance.
2006 TIGE 20V
"The boat alarm" is a pretty broad statement. Could you expand on exactly the sound of the alarm, beeping, constant beep, loss of power etc...? Most likely nothing to worry about but a connection to a sensor on the engine or transmission that was jogged when you hit the wave. A DTC reader would be able to tell you if there's a stored code in the ECM but beyond that you're looking for something that doesn't sound like it will be found unless you can replicate it.Fixing everyone elses boat just so I can use mine...
