My 2001 21V was leaking some water into the bilge and the rudder box was a prime suspect. There’s a nice write up on wake garage about removing and rebuilding the rudder box with the Marine Hardware seals.
https://www.wakegarage.com/projects-...-rebuild-r162/
If you want to go one better, have Tim at Glide Bearings do a rudder box blueprint. The Marine Hardware seal kit is $60 and will stop your leaking rudder box. Alternatively, for $175 Glide Seal will completely transform your rudder box into a slop-free and airtight unit. The difference in steering tightness and ease of turning is surprisingly noticeable. Huge upgrade over stock.
