When I start my boat the depth finder alarms and the depth finder display in the multi function speedometer flashes and is greyed out—all pixels flashing. This usually stops in a few minutes. When it is doing this none of the buttons work, in terms of changing the mode, etc. I am thinking the issue is the tri-function transducer. The part number for the old intelligent tri transducer is 20-435-01. I found the original paperwork and it is a DST800, so I found a DST800 on line and purchased it. When I got ready to swap the transducers, I found that the old unit has seven wires and the new unit 5 wires. On the old unit, the wires are blue, black, red, green, white and brown wound with a ground wire. On the new unit, blue, black, red, white and bare (ground). I guess my question is whether they are indeed compatible, and how to wire them. I don’t care about making the air/water temperature work. I had to replace the tach a couple of years back and lost the air/temp function. Any help or input is much appreciated!
2006 Tige 22V depth finder issue
