2004 22V
fine up until the other day then overheated at idle, revved cooled it down, the day went on an wak taking 4k in neutral to cool it.
Pulled impeller and pump housing looked perfect, was not unbounded.
Saw grooving on cover plate so replaced pump housing.
Flushed tranny cooler, flushed all the way up to circ pump, got some trash out, ran on trailer with the hose that feeds the circ pump hose disconnected, it was putting out a big flow.
rehooked it up, ran and eventually overheated.
Checked circ pump, no play in pulley, no grinding turns freely and no water at weep hole.
replaced tstat
Still over heated
strange to me was riser are cool. Manifolds are HOT
So now I figure getting enough cooling water to motor but it is not getting out.. I pulled the 2 block drains 1 on each side...nothing came out...dawned on me I might have sucked up sand from beaching, so I picked both out while running and cleaned a bunch of sand out until water flowed freely.
Figured I solved the problem but nope....same deal..
On a while I Pulled the line off the block drains again while one the lack,, very hot water came spewing out and temp went down and stayed down, water was much less hot coming out of drains.
Did I just come to the conclusion I need to pull the manifolds and clean the water exhaust holes?
I assume the hot water from the motor exits from holes in the block though the exhaust manifolds into risers and on out to the lake....
replaced tstat
Still over heated
