Upgrading my current propeller for R21. Confirming recommendation that Acme 1433 is way to go for surf/wakeboarding. Also should I purchase that C clamp prop puller or is that a gimmick?
Propeller Recommendation - 2016 R21
Id start by knowing what my current prop is. And "stock" is not an ACME model numberThe 1433 is a good prop, but may not be the best return on the investment. This why I like to know where the bar is set right now. Lake elevation? Do you need to travel long distance at a decent speed to get to a particular part of the lake? Always a large crew + lots of ballast?
No, the C-clamp puller is not a gimmick. Its the most efficient way to remove the prop. Its a purpose-built tool.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
