floor panel removal
    floor panel removal
    any tips or tricks to removing the back seat so I can remove the floor panel.Any advice would be appreciated thanks
    2005 22v sorry for not posting boat
      Remove the bottom cushions, and you should see a few screws there. Along the floor, there is a carpeted strip held on with 3-4 screws, but the heads are hard to see in the carpet. After removing the strip, you should see a couple more screws. That should do it and the seat box will pull out. After that, the floor will pull up.
        Thanks
          you have to take the rear seat "back" off too. There are 3-4 bolts/nuts that are accessed through the engine and v-drive compartments too. Piece of cake!
