Accessing the v drive and transmission
    Got a question I have a 2021 rzx23. To get to the v drive and transmission do you remove the floor where the cooler and trash can is? Is it just those two screws holding it down?
    On my old 3 it was a matter of removing the two screws. Lift up the engine cover, which hold the rear end of the floor cover in place. If you have the flip over seat it makes it harder. You either need to remove that seat or have someone hold it upright then slide the floor cover forward. You can't remove it all the way, but you can move it forward enough to get access to the drivetrain.
      Lift trash can and look
        I did v drive is to far back to get to it from there
          On my ZX1 it was just the two screws, lift engine cover. Lift like hell while not scratching anything on the way out! Makes maintenance/fluid changes on the thing a breeze!!
            I can’t get over how they don’t have a small door to at least check the fluids in the v drive and transmission.
              I've wanted to cut the top off the "step" in the cover then install a door like this one. Should help.
              https://www.amazon.com/Amarine-made-...51209605&psc=1
                Yes something like that. Crazy Tige didn’t do this.
