Getting the boat ready for the lake after winter and when I fired it up I noticed it wasn't pulling water. My "fake a lake" is a giant bin with 2 hoses pumping in and a line direct to my raw water intake.
Checked that there's a good seal from my raw water filter to the water bin.
Checked the transmission cooler - clear and basically appears no issues between intake and impeller.
I did change the impeller a few weeks ago when there was some nice weather, but I took off the cover and turned it over and confirmed the new impeller is spinning.
Also, if I hold the intake hose well above the boat and spray the hose directly into it, water does get through the system, but it doesn't seem to get any "suction" to pull water itself.
I also removed the block side of the impeller "output" line and started it up and similarly confirmed that it's not pumping water. (A couple of gushes will come out at startup, but then nothing).
I've seen a mention of needing to replace the impeller housing if there's no suction. Does this sound right? Believe it's a Jabsco? 2006 22Ve Marine Power 5.7.
The impeller is the water pump, right? There's not a separate pump somewhere is there?
Any thoughts/help are appreciated!
Thanks,
Blake
Thanks,
Blake
