I just bought a 1999 2100V that had 91 hours on it and the engine, transmission, and boat are in like new condition. The boat had not been drivin for 5 to 7 years. After changing the fuel pump, it stated right up and the engin ran strong and smooth. It pulled skiers up with no problem at all, but I did notice that while in gear at 1,100 to 1,300 RPMs there is a noticable increase/change in noise and slight vibration. It appears to be coming from the transmission or v drive unit? I checked the oil in both units and they are very clen and full. Any RPM above or below that range I do not hear or feel any thing unusal? I have never driven a v drive model and am wondering if this is normal or where the problem might be???
1999 2100v transmission problems???
The Chevy 350 V8 has a normal harmonic vibration right in that RPM range. If the prop is not dinged, or bent shaft, or loose motor/V-drive mounts, then id say that's what you are feeling.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by michaelxmas View PostI just bought a 1999 2100V that had 91 hours on it and the engine, transmission, and boat are in like new condition. The boat had not been drivin for 5 to 7 years. After changing the fuel pump, it stated right up and the engin ran strong and smooth. It pulled skiers up with no problem at all, but I did notice that while in gear at 1,100 to 1,300 RPMs there is a noticable increase/change in noise and slight vibration. It appears to be coming from the transmission or v drive unit? I checked the oil in both units and they are very clen and full. Any RPM above or below that range I do not hear or feel any thing unusal? I have never driven a v drive model and am wondering if this is normal or where the problem might be???
New Tranny
Here's my bad story. Test drove boat, performed flawlessly. Took it out for the first time with family and friends... engine warm, idled out, sunny day, ready to get on plane to get to another section of water, gave it the beans and...zippo. No power but plenty of billowing smoke from the engine compartment. Lots of it.
$4,000 later I had a new tranny and she runs like buttah.
B.O.A.T. Break out another thousand.
Originally posted by OldeBoy View PostWhat are these damping plates?
