2004 22v merc 5.7. Idler pulley squeaking for a while, wd40 for quick fix, today after a few surfing sets, start to run to the ramp and saw voltage low and temp up, neutral and looked at belt, it was loose so shut down and saw it came off water pump, spun pulley by hand and it turned like it should, hooked up belt. Started up but noticed same thing, looked and belt was off water pumo pulley, did this 2x more....
Took a closer look and noticed pulley and shaft looked it came out of housing by and inch or two, used a small hammer and tapped it back in. Hooked up belt and idled to ramp...all good.
But it did look like water pump shaft and pulley was moving in and out. Tensioner pulley was chirping so i
Pulled it, felt fine but need to replace is there a Automotive pulled that works?
Why is the pump shaft moving in and out, how is it captured in the housing?
