replacing a trailer ;-(
    Any one had to fork over some dough for a trailer? When I bought my boat, the trailer wasn't in great shape. Now it's in worse shape and I think I might need to replace it.
    These things ought not to wear out, but alas mine appears to be doing so. Anyone else bought a replacement trailer? Local shop? Dealer? What's your story?
    S
    What part of the country are you located in? You should be able to go directly to a trailer MFR.
      What trailer did you have?
        the previous owner of my boat ended up putting a new trailer on it and it cost him 8gees for it not the cheapest thing ....gal,electronic braking system was including in that price
          I got a quote from loadmaster for like $3800 for a 21' boat. Shop around or look for used one or have yours redone.
            what is wrong w/yours? rusting out? if so go w/a galvanized alum trailer.
              Trailer Pic
              I snapped a quick pic with my phone over the weekend of the trouble spot.
              Looks like a substantial crack and subsequent rust.
              Is this a repair that can be done in one day? i.e. lauch boat, fix trailer while boat in water, pull boat out?
              Sheb
                go to a local trailer shop - they can cut out that crossmember and replace w/another. If you don't have a boat trailer shop in your area, look for a good welding shop or utility trailer shop.
                  I'm with yllw 20 on this. Unless you have cracks and rust everywhere, I would repair it. A good welding shop can save you a couple grand.
                    Metalcraft
                    Called a local trailer manufacturer. On the phone they said they'll "refinish" a.k.a. take the trailer apart, sand blast, powder coat, and put it all back together again like Humpty Dumpty for $895.
                    No word on cutting & replacing cracked bit.
                    Good Price? Bad Price? What do you think?
                    I'd like to hear plusses and minuses of galvanized vs. powder coated trailers.
                      That sounds like a hell of a deal to me.
                        That is a good price
                          I'd jump on that, especially if they'll take care of the crack.
                          If it were my trailer, I'd just grind it clean and re-weld it myself. But that's me, and I have the right equipment.
                          The luck is gone, the brain is shot, but the liquor we still got.
                            shebodiac, where do you live? I want to take my trailer to this place!!
                              MetalCraft in SLC ?
