going to do service this season myself what do you all recommend for oil in the trans and v drive unit?
V-drive, if it's a Walter, should get 30W non-detergent motor oil and the trans should be the Borg Warner Velvet drive and will be Dexron III or higher.
Hey chpthril - I am changing out the oil in my Walter V-drive and noticed it seems to have some leakage from around the lower plate. Looks like I will need to replace the gasket on the lower plate. Do you know who supplies them around the Lake Wylie area or online? Thanks for the info..
Hmmm, I would try Walter directly, that sounds like an odd part for anyone to have on hand. How bad, is it s leak or a seep?
The leak isn't bad, drips just enough to create a greasy mess if any water gets up that high in the bilge. Not enough to create a problem for the V-drive though. After a little research, I came up with the same answer, I will go directly through Walter. Thx...PM
