Hey, i think by boat dealer, no longer a Tige dealer, swapped my prop for a somewhat damaged one. There is very little I can do now other then leave the dealership(which I have). My questions, I have a 2005 24V w/Vortec 389HP. What are my prop options? Repair? Replace? I noticed some vibration and did repair under water. However, I sure it's not 100%. Doesn't feel like I have as much power as I had before. Does this make sense? Would an ACME 275 13.5, 17.5,LH, 1 1/8bore work well? Thanks...
dennis
Originally posted by Denlakewp View PostHey, i think by boat dealer, no longer a Tige dealer, swapped my prop for a somewhat damaged one. There is very little I can do now other then leave the dealership(which I have). My questions, I have a 2005 24V w/Vortec 389HP. What are my prop options? Repair? Replace? I noticed some vibration and did repair under water. However, I sure it's not 100%. Doesn't feel like I have as much power as I had before. Does this make sense? Would an ACME 275 13.5, 17.5, 1 1/8bore work well? Thanks...
2nd, baring high elevation or a 1:1 gear ratio V-drive, your 24V more then likely came with the ACME 537 from the factory. The next best upgrade for most folks it the ACME 1235.
What color is the boats V-drive and at what elevation do you boat and what prop is on your boat know, the 275?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
