I have a 2004 Tige 22v with 350 Mag Tow Sports Engine. What prop size should I have if I want to get an extra prop?
Prop Size
Need to know what trans ratio you have now, it could be a 1:1 even though 1.5:1 was more common. The Blue Walter is the 1.5:1 and I think the black Walter is 1:1 Do you want to upgrade, or just looking for a direct replacement for what you have now? The size and part # should be stamped on the hub of your current prop, if it's convenient, let us know what size you have now, and whether it's a 3 or 4 blade.
I may be placing a prop order to ACME in the next couple of weeks, If I can get 6+ orders, I can pass on a dealer price break.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
The Black Walter V is 1:1 and the blue is 1.4:1. I have the blue one in my boat. As CHP said we need all the information to best set you up for the best prop. What side of the country are you on?www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
