Question 1: I removed my 4-way combo gauge (fuel, volts, temp, oil pressure)to send it to Faria for repair. I tried to make careful notes on which wires were attached to which posts on the back of the gauge (there are about 20 wires attached to that sucker), but I'm not entirely sure I recorded it correctly. Does anyone have, or know where I can get, a wiring diagram for the back of that 4 combo gauge?
Question 2: The engine now won't fire (it turns over fine) since I removed the combo gauge. Someone suggested I may have blown the ignition fuse in the process of removing the combo gauge - but I can't find a fuse anywhere under the dash on the purple ignition wire. Can someone tell me where such a fuse would exist - and is there any other reason the engine would not fire with the combo gauge removed?
Thanks much for your help.
CJN
CJN
