Sorry if this has been brought up here before. I have a 2006 22V with the fiberglass swim step. never had a problem before this year, but now when you walk on the swim step when it is wet, then into the boat, it leaves nasty black water on the seats. is there something to seal the rubber or has anyone else had this issue?
Swim step "Residue"
Common problem. My solution was to remove the factory traction pad and replace it with Gator Grip. Hated the old stuff - not only did it track in black residue, but it was hard and harsh. Gator grip is soft and non-slip. There are several threads that talk about replacing it. Not sure if there is a "fix" for your current pad.
The rubber "e" mat needs to be replaced. Not entirely sure that it's a warranty issue but you can call your local dealer.
There are other products on the market that you can replace the mat with. All three of these products are far superior to what Tige provides IMO.
1) Gator Grip (www.wakejunky.com)
2) Hydro Turf (www.hydroturf.com)
3) SeaDek (http://www.seadek.com/)
