Cluster problems
    Cluster problems
    I am new to these forums, so if this info is out there, please send me too it.
    I just bought a 2000 21v rider edition with 275 hrs. When I went for the test ride on the boat, all seemed to work as planned. Now that I have the boat, it seems that all of the on/off switches on the dash do not work. I have no blower, bilge, or stereo. Is there something common to all of them that I should check? To me it seems as if something came loose. The only thing that changed was that we unhooked the battery when we left the lake after the test ride.
    If you need more info, let me know and I will gladly answer.
    Mine has two white switches under the stearing wheel that shut off all power.
      You just failed to reattach the smaller cables to battery that powers all of that stuff. There is a very large cable and some smaller ones (sometimes several). Just look around you'll find them in there if you haven't already.
      Biggest lake addict on the planet
