Can someone tell me how much and how hard it is to install perfect pass.
Pefect pass
I paid like 1100 for my PP wakeboard pro. Difficulty of install is kinda subjective, how mechanical are you? change oil, etc.. Older version (one I have) required a paddle wheel= big hole in bottom of boat. Not that "hard" just requires measure twice type deal. Newer style is gps version would be that much easier. Customer service from PP is top notch.
Depends on the system.
For a 2002 you need a mechanical servo driven system. Depending if you want Stargazer Wakeboard Pro ($1200) vs. Stargzer Digital pro ($1400) is the difference of about $200.
It is relatively easy to install now that its GPS based. You will not have to drill any holes in your hull. You will have to replace a guage, install the Master Module, install the servo system, and run a few wires. It seems like a lot but it really isn't and the installation instructions are complete and easy to follow.Common Sense is not so Common
