I will try to answer your questions, and if I'm not 100% correct, anyone is welcome to chime in. Basically GM build the engine- block, pistons, heads, valve train, etc. Merc, Indmar, PCM, and Marine Power buys the assembled engine and maritinizes it- or they put on the water pump, alternator, or basically everything that hangs off of the engine. The last that I heard, it comes from GM with even the fuel injection. The computer or brain of the EFI may be done by the engine outfitter, I'm not sure of that. The exhaust manifolds are also my the outfitter.
So if you only care if you are getting a GM engine, then buy anyone's, because right now they all come off the same line. There are no differences to the long block. Merc, Indmar, PCM and MP also buy and couple the transmission and V-drive (if it has one). This also comes from a third party But if there is a problem, you look to Merc or PCM for help- not GM. If you think about it, when was the last time you heard about a problem with the basic engine- internal to the block. Never. The problem is useually the water pump, transmission, electronics, or something that the final engine maritinizer did.
In my opinion, all of the little stuff that gets added to the engine along with how they stand behind their product, makes a big difference.
Indmar must be good too, since there are a lot of happy Malibu and MasterCraft owners. PCM is owned by Pleasurecraft Engines. I assume that Tige still offers them too. Ask your dealer, but they are probably $3-4,000 more.
The story I heard about Marine Power is they are a smaller company in Louisiana that did mostly commercial stuff, and recently got into the competition boat market. When you sell stuff for ocean and commercial use you have to have it right. A hold-over from that market is the dual alternator belts. If one breaks, you still have one. They are the only mfgr. to mount the starter on the top of the bell housing. This way if you get a little water in the bottom of the boat you will not ruin an expensive starter, or get stranded.
Good luck with the decision and purchase. If you have a good dealer, no worry.
